Flash ROM on version BV7000_PRO_Blackview_20170516
Tue May 23, 2017 11:29 am
Below is the Flash ROM on version BV7000_PRO_Blackview_20170516.
https://mega.nz/#!Ue5DhAxL!cpaZoVECEkPo ... xyKEqj2HEE
Debuggings:
The grey background of clock/music/manu changed to black, optimize the OTG charging function.
Holefighter
Re: Flash ROM on version BV7000_PRO_Blackview_20170516
Tue May 23, 2017 2:55 pm
But its still Android 6 right? When can we geht 7?
incaderelibera
Tue May 23, 2017 6:56 pm
Since updating to the latest version, I am not able to receive or make any calls, the previus version had issues with the calling quality . Data works fine, phone has been reset few times and other sim cards added but not having any luck. When checking call barring settings I get: "Call settings error, Network or sim card error". Sim card works well on other smartphones. I really like the phone, let me know if there any solution for this. Thank you
sven_s
Tue May 23, 2017 7:29 pm
Can you post a guide how to install the Flash rom for bv7000 PRO?
lpossamay
Wed May 24, 2017 3:02 am
incaderelibera:
I have a problem close that you describe, but my phone is able to make or recive one call. After this call, it do not receive or make more calls, until reset or power cycle, I am waiting solution, may be this solution work for your phone too. If the phone was working with the previous ROM, you can download it, and install back, blackview has this information available.
sven_s:
Here you can see a link, how to download Flash Tool program, and install the ROM.
Be carefully when you select the options, if you select format and download software you may lost the IMEI and is necessary to acces by engineering mode to program it again, and the procedure is different for different ROMs. (https://androidmtk.com/flash-stock-rom- ... flash-tool). May be the administrator want to share with us more information, if mandatory to program another parameter, or a procedure to save all important parameters before flash the phone.
incaderelibera
Wed May 24, 2017 8:18 pm
Hello.
I have used few times the Flash Tool program to successfully install the firmwares: "BV7000_PRO_Blackview_20170320","BV7000_PRO_Blackview_20170411" and "BV7000_PRO_Blackview_20170516" as well as updated OTA the phone to the latest version "BV7000 PRO Blackview 20170523" but making/receiving calls has stooped altogether still getting "Call settings error, Network or sim card error".
Fri May 26, 2017 6:07 am
Yes. For the already delivered ones, we are sorry can not help.
But in the middle June, the BV7000 Pro will be shipped running Android 7 directly.
Fri May 26, 2017 6:42 am
Please find the guide in the below.
SP flash guide.docx
(367.94 KiB) Downloaded 613 times
kup0
Fri May 26, 2017 10:16 am
So Blackview is not going to release Android 7 update (OTA or manual download from web site) for bv7000pro?
incaderelibera
Fri May 26, 2017 11:28 am
Hello.
When I purchased the BV7000Pro worked fine for few days then call quality was affected and now it has stopped working. Tested few SIM-cards from two different network providers that work just fine on other smartphones but I keep getting 'Invalid Sim' after start and the call barring settings are not available. These errors are showing on three different firmware. Could you please advice for a solution on the "invalid IMEI" issue?
Much appreciated
