Holefighter
engineer mode
Tue May 23, 2017 11:08 am
I read that i can open the engineer mode with *#9646633#
thats cool, but what can i do there and what are the highlights?
Can i make my mic or speaker louder? or what is it for?
Or is it only for testing and infos?
Phil
Re: engineer mode
Tue May 23, 2017 11:17 am
it's for testing, calibration and for "hidden" settings. You can also change the speaker level. (Hardware testing>audio>volume>...). But be sure what to do when you change other settings you don't know. This could give strange results.
Holefighter
Re: engineer mode
Tue May 23, 2017 2:49 pm
OK thanks. Is there something i should change? Like the speaker or something?
Holefighter
Re: engineer mode
Tue May 23, 2017 3:31 pm
Is it also possible to make the phonecall(speaker) louder?
Phil
Re: engineer mode
Wed May 24, 2017 8:02 pm
yes. just increase the value of loudest setting
Holefighter
Re: engineer mode
Thu May 25, 2017 5:14 am
And what can i do with the camera settings in the Engineer mode?
Phil
Re: engineer mode
Mon May 29, 2017 11:24 am
If you don't understand the settings there please don't change it!
Holefighter
Re: engineer mode
Tue May 30, 2017 1:57 pm
OK. I thought i can fix my camera because the camera will not focus. AO i habe to send RhE phone back to blackview
