SiBaKo
FingerPrint working a couple of hours
Mon May 22, 2017 6:22 am
I have problem with my Fingerprint unlock, when i set fingerprint, it works well for a couple of hours, then it seems as BV7000PRO forgot my fingerprints.......? When i set new FIngerprint, it is same, works for couple of hours.
I have Android 6, Build number BV7000_PRO_Blackview_20170411
Phil
Re: FingerPrint working a couple of hours
Tue May 23, 2017 11:13 am
I will test If I have the same problem.
Phil
Wed May 24, 2017 8:24 pm
It is working for me. Did you install or activate some kind of battery saver?
If not maybe you should try a factory reset.
