Any update on your success with Straight Talk? I'm into it about 8 hours over 3 days and although getting phone calls and SMS text going was fairly easy using the straight talk T-Mobile sim, data is still not working. The last (and supposedly most compatible) data settings they provided were:
X_PARENT_NAME : T-Mobile
RATE_PLAN : TracFone STW TTW2
ORG_ID : STRAIGHT_TALK
APN : wap.tracfone
AUTH_TYPE : None
MMSC :
http://TF.mmsmvno.com/mms/wapencMMS_APN_TYPE : default,mms,supl
They said to only fill in the ones where there is a relate-able category in the APN setup.
I'm in Vermont in an area with strong LTE coverage known to work on other phones. It's somewhat hard to believe a flagship phone wouldn't be compatible. Does anyone else have working data for which they can share their APN settings?
