cgoulas
USB cable does not work
Thu May 18, 2017 9:11 pm
the usb cable provided seems to be low quality and you have to "bend" it towards different directions in order to find where exactly it allows the phone to be charged.
Please advise on either warranty or where I can buy a couple of spares.
For the moment I had to slice the plastic on another usb cable in order to charge the phone, but that also does not make a good connection.
Thanks in advance.
