nesterov32
Blackview P2 Lite
Thu May 18, 2017 2:59 pm
Hey. The phone was released, and where is the firmware? There are drawbacks in the operation of the smartphone, it does not connect to the laptop with Windows 7, the first time you turn on the phone when the contacts are transferred to the phone, the Phone application error pops up. People on the forum complain that their interlocutor can not hear, the settings in the engineering menu are corrected, and so on. When will the firmware update all this correct?
Re: Blackview P2 Lite
Mon May 22, 2017 6:13 am
Flash ROM P2 Lite_Blackview_20170413
https://mega.nz/#!wDIyiJYa!chXw4PuRFz4C ... iuDRSYVL5w
cazac9
Tue May 30, 2017 6:27 am
Having the same issue with microphone and contacts importing from google account, Does this update fix both issues?
deveci08
Tue May 30, 2017 6:57 am
Please refresh Zip file is corrupted
nesterov32
Wed May 31, 2017 1:38 pm
Hey. This archive is damaged, do not you read what you write? Lay out a normal file with the firmware. And how long will you solve the problem with microphones? And then already in time to send phones to sellers, and demand a refund!
pavebaranov
Wed May 31, 2017 6:11 pm
Correct the problem with the microphone in the apps phone as quickly as possible. Phone is not possible to use. Thank you.
