frofa
20170414 TWRP and rooting
Tue May 16, 2017 10:07 am
Hi all, I want/need to root my new BV6000, so I followed several instructions on the web how to do it. I have experience with other MTK phones before, so I thought it would be a piece of cake. However, after I flashed TWRP, I can boot into it, but the touchscreen does not react. I suspect that this is because my phone is running the 20170414 ROM, and most probably the available TWRP versions do not work with this new ROM.
Does anyone have successfully rooted his BV6000 with 20170414 ROM already? Is there a TWRP version that would work? Or is there currently no way to root the phone and all we can do is wait? I really need my phone rooted, for a variety of reasons...
khubeo
Re: 20170414 TWRP and rooting
Tue May 16, 2017 3:55 pm
Connect a computer mouse to the phone, it works.
frofa
Tue May 16, 2017 5:13 pm
It is beyond my understanding what this answer has to do with my question, but be it as it may, thanks anyway ;)
khubeo
Tue May 16, 2017 5:25 pm
You said touchscreen in TWRP does not react? So I understand it means you cannot use the items in TWRP, because it is a common problem. You solve this problem by using a mouse.
frofa
Tue May 16, 2017 9:34 pm
Wow, that's a cool option I did not think of at all. But you're right, that might work. I have to flash TWRP again tomorrow (it always becomes overwritten upon boot because I could not enable persistence due to the problem with the touchscreen), and will try it immediately after flashing. I'll report if it works that way.
frofa
Wed May 17, 2017 8:28 am
khubeo, YOU ARE MY HERO! With a mouse attached via OTG, I could use TWRP and my phone was rooted in seconds!
khubeo
Wed May 17, 2017 12:07 pm
I'm glad thad it helped you :)
bvbw
Wed May 17, 2017 9:16 pm
Could you share links you use for rooting ? (TWRP, drivers W10, etc ...)
Thanks
khubeo
Thu May 18, 2017 5:35 am
I don't have any experience with win 10
