JF_BV
How to assign the 'recent apps' fonction to the 'menu' key ?
Mon May 15, 2017 8:36 am
On my Blackview BV7000 Pro, I'd like to change the 'menu' key (which is rather useless on the new
Android interface, holding the 'back' key as the same effect) by the 'recent apps' key.
It's a waste of time to hold the 'home' key to access recent applications. On most modern
Android phones there are 'recent apps', 'home' and 'back' keys.
In addition, Android 7.0 introduces the ability to double tap on 'recent apps' key to switch between the last two applications opened.
Do you know how to assign the 'recent apps' fonction to the 'menu' key ?
Thanks (sorry for my english)
