tomithyom
Tools for BV6000?
Sun May 07, 2017 4:34 am
I'm looking for tools for the BV6000.
I've worked out that the side star tool is a T5 Torx screwdriver.
What about the hexagonal screws on the back of the phone? What size are they and where can I get the tool from?
Thanks
khubeo
Re: Tools for BV6000?
Sun May 07, 2017 9:58 am
The screws on the back side are common hexagonal sockets (allen key) 1,5 mm
97gérard216
Tue May 09, 2017 12:29 am
Torx screw T5 & T6 for BV6000 see this link:
https://www.aliexpress.com/item/26-in-1 ... fe09440460
tomithyom
Tue May 09, 2017 7:20 am
Thanks all. I can confirm that the back is a 1.5 mm allen key.
As for the kit you have shown me above, it's funny but I just bought this last night. Obviously I made the right choice. Cheers. :D
