gandrew
Service Center / Replacement Battery
Sun Apr 30, 2017 3:18 pm
Hi, I was wondering where I can have my BV6000 checked in Hong Kong, I'm looking to have a professional look at it, or at the least be able to buy a replacement battery. Thank you.
Re: Service Center / Replacement Battery
Tue May 02, 2017 7:04 am
You can buy a replacement battery from the below link.
https://www.aliexpress.com/item/New-Bla ... 5529efeaa4
Skyess
Fri Jun 16, 2017 3:16 pm
The Link of the battery replacement is that the ph-h756062p-a4-p0029 4500mAh 17.10Wh. 3.8V
Because looking at the picture you can´tsee that information.
And i´ve looked for a little wile now and it seems to be always the battery for the bv6000s. who is 4200mAh
