ROM of E7S_Blackview_20161205
Wed Apr 26, 2017 9:30 am
Hi everyone, below is the ROM of E7S_Blackview_20161205.
https://mega.nz/#!MKwVnDRY!Qcvr3Tqrpz2O ... ieipND8u6w
engr.umairshah87
Re: ROM of E7S_Blackview_20161205
Thu Apr 27, 2017 5:58 am
Dear sir, can you please guide me how to install this rom. I am currently using _20161202_105939. The problem with my current ROM is that after every reboot my mobile language changes from English to Arabic ( When Saudi SIM card inside) .
engr.umairshah87
Thu Apr 27, 2017 7:09 am
Hi sir, can you please update me how to install this rom. Also with the last ROM 20161202 I had problem that the language of my phone changes to SIM card language after every reboot.
Fri Apr 28, 2017 6:06 am
You can follow the flash manual on this page, it can also be used on your phone.
viewtopic.php?f=2&t=115827&p=294022&hilit=MTK+smartphone+Multiple+downloading+tool+operating+instructions#p294022
engr.umairshah87
Sat Apr 29, 2017 10:18 am
Thank you very much for your support sir. After update I lost my IMEI and now I cannot recover .
engr.umairshah87
Tue May 02, 2017 9:33 am
Please help me restore my IMEI
ishawahni
Sun May 21, 2017 9:04 am
engr.umairshah87
use the following code : *#*#8688#*#*
it will help you to write your IMEI for both sims, you can find your IMEI under battery and on the Packet which came with the mobile device.
Please let me know if this helps you.
If so, can you please let me know if this ROM solves language auto switch issue and other improvements, because I'm still afraid to flash new ROM and get nothing.
Regards
Ibrahim Shawahni
ishawahni
Sun May 21, 2017 9:10 am
use the following code *#*#8688#*#*
it will help you rewrite your IMEI which you can find on the back of the phone under the battery or on the box of the phone, please let me know if this works with you and if this ROM solves language auto switching problem.
Regards
Ibrahim Shawahni
jpgr2000
Fri Jun 16, 2017 12:14 am
Hello everyone, as everyone know, this devices has a gpu mtk6580, my question is if is there a flash tools rom?
thank you very much
:D
