How to use PTT function inBV7000 Pro
Wed Apr 26, 2017 7:11 am
As the popularity of PTT(Push-To-Talk), #Blackview #BV7000Pro has also been built with PTT function.
While this popular PTT in BV7000 pro makes you and your team in good communication and more convenient, safe with each other.
Tri-proof rugged BV7000 Pro is not only a phone especially using at outdoors, team adventure series, etc.
https://www.youtube.com/watch?v=wk6LT5DIw5c
Whiteview7pro
Re: How to use PTT function inBV7000 Pro
Mon May 15, 2017 5:33 am
is possible convert ptt key in sos key (in the future...). this is rugged smartphone used for work in external space
Phil
Tue May 16, 2017 10:07 am
it's not a ppt key, it's a smart key. It can be set not only to start ppt but to start any app you like.
Whiteview7pro
Thu May 25, 2017 3:37 pm
i hope in the future it's possible, insert a script in the main system... simple for enginering
Tue Jul 25, 2017 1:26 pm
I reported this as a feature request. But already today you can use the key to start any sos-app you find in the app stores.
Whiteview7pro
Sun Aug 13, 2017 8:03 pm
any news ?
Mon Aug 14, 2017 7:09 pm
sorry, no. I fear it will not be possible for this device.
