Laurre
Keyboard vibration
Tue Apr 25, 2017 11:30 am
I'm french so i don't speak english very well, so please be gentle with me.
I have theorically disabled the vibration when i touch the phone, but it doesn't worked on the keyboard, how can i do it?
Thanks for your answers.
Laurre
GRIZZLY06
Re: Keyboard vibration
Tue May 09, 2017 5:55 pm
Bonjour Laure, je suis également Français, pire: Corse :mrgreen: , et j'ai le même problème: impossible de désactiver le retour vibreur des touches lors de la saisie.
J'ai contacté Blackview, mais pas de réponse, j'espère que ca va le faire avec vous.
Crdlt
Phil
Wed May 10, 2017 10:13 am
Disable general vibration-feedback: go to settings>sound&notification>gearwheel behind your sound profile> and disable "vibrate on touch"
Disable Keyboard vibration: open keyboard > long press ,-button (left to the space bar) > android keyboard settings > preferences > and disable "vibrate on keypress"
GRIZZLY06
Tue Jun 27, 2017 7:47 am
Ok Phil, it's all righht for me.
Thank a lot :mrgreen:
