cantarruim
IMEI is invalid
Tue Apr 25, 2017 3:53 am
Hello, I have a problem, about 10 days covering the blackview p2, however the software is not opening a game store, is decide to reinstall an appliance room, do this is to use the original available in the forum that site and installed by the program SP Flashtool, but after the reinstallation of a memory unit, the device does not make the connection, "IMEI invalid" appears to try to add the IMEI that is in the device box with the program Adding the correct files, so I would like to request Help and a step to add the IMEI, also do not have much knowledge about the production, I look forward to return. :oops:
Re: IMEI is invalid
Tue Apr 25, 2017 6:27 am
Did this problem happen after this below update?
ROM of P2 on version P2_Blackview_20170307
M8th3w
Re: IMEI is invalid
Thu Apr 27, 2017 12:34 pm
I have the exakt same problem after I installed the P2_Blackview_20170307 version
Re: IMEI is invalid
Fri Apr 28, 2017 6:04 am
Did you update it by formatting? If so, the data in your phone will be damaged.
M8th3w
Re: IMEI is invalid
Sat Apr 29, 2017 4:08 pm
Yes I flashed the ROM and I know the risk of losing the IMEI during this process. Nevertheless I've got an IMEI after the flash. But it says invalid. Even if I change the IMEI - always invalid. Any suggestions?
cantarruim
Re: IMEI is invalid
Sat Apr 29, 2017 11:07 pm
Yes, version 20170307 how do I solve the problem?
Bernie_W
Re: IMEI is invalid
Mon May 01, 2017 8:56 pm
Right, if you use SP-Flash and choose Format, then your NVRAM will get deleted. You should only use update or download, all other can kill your phone.
If you do not have a copy of your NVRAM folder, you can only try to install your original firmware or try the MTK engineering tools to set the imeis again or search for mauimeta or chamelephone, those two apps may help, but it not always works.
bulletwara
Re: IMEI is invalid
Tue May 02, 2017 2:16 am
Please give an instruction on how i can update my phone... will it work if i extract the rar files & convert it to zip file & run the wireless update & choose local files ? thank you
M8th3w
Re: IMEI is invalid
Tue May 02, 2017 10:31 am
Ah sorry, I've misunderstood the admin, I didn't choose download + format in the sp flash tool. I used only download to flash the new rom.
Bernie_W
Re: IMEI is invalid
Tue May 02, 2017 6:11 pm
That is strange then, because SPF should not overwrite your NVRAM. But you can still try my suggestions or even try a re-flash again.
