velmafia
Lost IMEIs after flashing
Tue Apr 25, 2017 2:33 am
after flashing new ROM (BV6000_Blackview_V01_20170414: https://mega.nz/#!dLxRSCIS!42alvYGKTr-7 ... F98EPfyWb4), I lost my IMEIs. Probably because i make "Format All + Download" in SP_Flash_Tool.
I tried to restore IMEI by SN_Write_Tool ( http://www.android-hilfe.de/thema/anlei ... en.797411/ ), but I have error:
EnterAPMetaMode() : MetaResult = SPMETA_DLL::META_MAUI_DB_INCONSISTENT
How can I restore my original IMEIs?
BR.
Kamil
Re: Lost IMEIs after flashing
Tue Apr 25, 2017 7:23 am
Please do not update by formatting, the data will be damaged.
You can write the IMEI yourself, we will send you the instruction tool to your mail.
velmafia
Tue Apr 25, 2017 10:10 am
Unfortunately now - I know this.
Thanks for instruction, what you sent to my e-mail, but I still have problem with:
I found in google that this error mean problem with wrong database file - I use this files from last firmware (20170414_s12v55_jk_3m)
MD1_DB: MDDB_InfoCustomAppSrcP_MT6755_S00_MOLY_LR11_W1603_MD_MP_V35_4_P19.EDB
AP_DB: APDB_MT6755_S01_alps-mp-n0.mp7_W16.38
this is correct files? If not - where I can find correct files?
velmafia
Tue Apr 25, 2017 9:58 pm
investigate my problem with google, and I found information that MetaResult = SPMETA_DLL::META_MAUI_DB_INCONSISTENT error meaning "The DB file(s) being used aren't compatible with SN Writer", so I try to use another version of SN_Write_Tool, and trail and error method I find SN_Write_Tool_v1.1648 version. It's working with BV6000_Blackview_V01_20170414 and BV6000 Blackview V01 20161025 (unofficial).
So:
#1.DON'T use option Format All + Download, if you don't want problems.
#2. before flash - make a backup nvrom, or whole phone (tutorials available in web).
@blackview_admin - thanks for help!
BR.
Kamil
velmafia
Tue Apr 25, 2017 10:00 pm
So:
BR.
Kamil
gwrudy
Fri May 19, 2017 11:32 am
my name Rudy and I have trouble like Yours. I loss my IMEI because flashing ROM by "Format All + Download".
would you please send me by e-mail. step by step that was what you doing to recovery the IMEI.
thank you for your help.
best regard,
rudy
e-mail: iniemailrudy@gmail.com
HIERARCHY666
Fri May 19, 2017 2:30 pm
Can you send me too? I have the same problem. Watching the video on youtube you guys posted without guide is so hard. Is it download mode? Is it Fastboot mode? What mode? Battery out or in? So much questions without guide.
HIERARCHY666
Sat May 20, 2017 8:44 pm
Hi, i need your help with the tutorial on fixing my IMEI. Please help i urgently need it as i couldn't make any phone calls right now.
hierarchy6@gmail.com
Mon May 22, 2017 6:09 am
You can re-write it yourself, hope the below file can help you.
VC SN Tool Introduce.pptx
(577.49 KiB) Downloaded 754 times
Parcheval
Mon May 22, 2017 7:52 am
