mvdwege
High power use of the WiFi chipset
Mon Apr 24, 2017 8:33 am
I am very happy with my new BV7000 Pro so far, but I did notice that whenever WiFi is on and used regularly, the battery drains faster than I am used to. My previous phone was a BV6000, and I ended the work day usually with some 60-70% battery remaining. The 7000 regularly drops to below 30%.
And it is the WiFi, as the battery settings page reports it as the #1 power user, and turning it off dramatically increases battery lifetiime.
Is this a normal consequence of the new 5G chipset, or will this be fixed in a driver update later on?
Re: High power use of the WiFi chipset
Tue Apr 25, 2017 6:05 am
Hi, you can try to update the currently version on your phone to see if can solve this problem.
Dsm0210
Tue Apr 25, 2017 6:41 am
Same problem solution please!!!!!!!!
Dsm0210
Tue Apr 25, 2017 6:42 am
Dsm0210
Tue Apr 25, 2017 6:44 am
Dsm0210
Tue Apr 25, 2017 11:10 am
The problem was solved with the BV 6000 update to android 7
Dsm0210
Tue Apr 25, 2017 11:12 am
And anyway apart from the battery and then also data connection always solved by switching to android 7 on bv60000
mvdwege
Tue Apr 25, 2017 11:38 am
Hi admin,
Current firmware version is BV7000_PRO_Blackview_20170411-172021; the phone downloaded and installed this when I took it out of the packaging, and it reports no newer version right now.
@dsm0210 Switching to Android 7 on a bv6000 is obviously not a solution.
Dsm0210
Wed Apr 26, 2017 6:11 am
@ mdvwege I don't know but the problem was solved
Fabietto
Tue May 09, 2017 7:34 pm
Hello, I have the same problem of power consumption probably related to wifi. My brand new bv7000 pro runs out of battery in roughly 12 hours with regular usage. (no games, no filming, no nothing); furthermore, it seems to become quite warm in the upper back area.
My wireless Update shows BV7000_PRO_Blackview_20170324-210250 and as I search the wireless updates it respondes that my device is up to date.
I have a basic knowledge of android and, since my phone is really new I don't want to mess around with it.
Please give me some simple explanations of what I am supposed to do. If the problem persists I will have to return it to Amazon.
Thank you.
