Carlos matos
Black lcd
Sun Apr 23, 2017 7:20 pm
I have a bv60000 asked me to update, updated and stayed with the black screen. He works and everything is not seen nothing is black. Help me solve the problem
Re: Black lcd
Mon Apr 24, 2017 5:57 am
Can you please try to turn it off and reboot it?
Carlos matos
Re: Black lcd
Mon Apr 24, 2017 12:19 pm
I've done it but it always happens the same. Neither blackberryw appears to connect the lcd in black.
Carlos matos
Re: Black lcd
Fri May 05, 2017 11:02 am
Me ajudem por favor
Não sei mais o que fazer :( :(
Carlos matos
Re: Black lcd
Fri May 05, 2017 11:13 am
Carlos matos wrote:
I've done it but it always happens the same. Neither blackview appears to connect the lcd in black.
Phil
Re: Black lcd
Fri May 05, 2017 11:16 am
You can try if flashing a complete new ROM over your computer will help. It's not that easy but might help maybe.
BV6000
Re: Black lcd
Fri May 05, 2017 6:04 pm
Carlos trata de fazer un reset coa app flash tool dende o PC. Fica tutorial en youtube o nestes foros
o desarmalo, quiza deuse un golpe forte e soltouse algo no interior
Carlos matos
Re: Black lcd
Sat May 06, 2017 7:38 pm
Já tentei mas tenho que ter o deporamento USB ligado e eu não tenho . O meu PC não o reconhece . Há alguma maneira de o ativar ?
Phil
Re: Black lcd
Sun May 07, 2017 7:03 pm
Just to be shure you tried correct:
  • Don't connect smartphone
  • Start and prepare flash tool
  • click start
  • connect smartphone
If that don't work, here is an complete instruction incuding installation of the correct driver: viewtopic.php?t=54240
