kaszlak
BV7000 Pro Rooted ROM
Sat Apr 22, 2017 1:25 pm
Hello ,
Dear BlackView team could you prepare a preroted rom or tutorial how to root device ?
Re: BV7000 Pro Rooted ROM
Mon Apr 24, 2017 3:10 am
Hello, we don't advise you to root your device, this will be causing damage on your phone and can be hardly fixed.
Elena
Sun May 07, 2017 12:02 am
Could through the root the 3G bands WCDMA 850/1900 MHZ and 4G LTE FDD 1900 MHZ be enabled ?
Because in Ecuador only work with these bands and the Blackview BV7000 does not work.
Or is it already a hardware problem and has no solution? To return my Blackview BV7000 phone.
OZVS
Fri May 19, 2017 11:53 am
Hi
While installing the authentication apps for my e-banking on my brand new Blackview bv7000 pro I received the message: rooted android! and the app is not functioning. I let the app check root run. This one indicated, of course not rooted, but the security net check said CTS profile match fail. I think it is the reason why the authentication app said rooted android.
Is there a way to correct this problem?
Phil
Sat May 20, 2017 9:01 am
I read this before and tested this with my banking app. It works well. Do you use the latest Firmware 20170411?
OZVS
Mon May 22, 2017 3:33 pm
Yes,
I received my phone with the 20170411 already installed
Phil
Tue May 23, 2017 10:43 am
- which banking app are you using?
- what do you mean with "I let the app check root run" - the root integry check in recovery?
OZVS
Tue May 23, 2017 11:43 am
Hi Phil,
I'm using the CrontoSigned Swiss app. I was not able to get more information than: "Ah there should be a security setting problem on your phone, you could buy the specific device for it"
As i,m not at all a specialist of rooting phone, I download the App Root Checker from Google play store and run it on my phone. The results was not rooted for the root check and for the safety net check: failed (CTS profile match fail.
Phil
Wed May 24, 2017 7:57 pm
with the first ROM for this phone was a problem because is was not signed as "release", bis this should be solved for long time.
I have no Idea what's the problem of your app. Maybe you can speak with the bank support?
OZVS
Thu May 25, 2017 8:24 am
Actually they have just released today an update of the app, and now it is working fine! I should be able to enjoy fully my Blackview.
