grAwp
Phone charger (BV7000 Pro) is so loud
Sat Apr 22, 2017 7:49 am
Dear Blackview,
I received the order from the seller and I have a little problem with my new phone BV7000 Pro. If I charge it, the phone charger squeals so loud - some noisy sound. What can I do with it ? I think the charger is faulty, can you give me a replacement ?
Thank you ;)
Re: Phone charger (BV7000 Pro) is so loud
Mon Apr 24, 2017 3:30 am
Hello, please go to online shop and ask for a replacement. Hope this will help.
grAwp
Thu Apr 27, 2017 9:03 am
Are all the chargers so loud ? You can test it ? Thank you
Tue May 02, 2017 3:51 am
We just received this only one user feedback on this issue.
Phil
Fri May 05, 2017 10:02 pm
I just tried my charger for the first time and I heard really nothing.
grAwp
Wed Jun 14, 2017 9:13 am
Ok, i sent my bad charger to shop wherei bought the phone. I am waiting for solution from shop.
