ROM of BV7000 Pro version BV7000_PRO_Blackview_20170411
Thu Apr 20, 2017 9:48 am
Hello everyone, below is the latest ROM of BV7000 pro version BV7000_PRO_Blackview_20170411
https://mega.nz/#!gTQGVT4a!j474f016AmZZ ... -xmvSBx6_E
archiem
Re: ROM of BV7000 Pro
Thu Apr 20, 2017 12:08 pm
Thanks !!
lamerv
Thu Apr 20, 2017 5:15 pm
Admin, I have a few questions.
I know from the 4pda forum that some users have received updates (wireless update) to the latest version - 20170411.
But other users who have firmware 20170224-164843 did not receive updates by air. Why? Will these users receive updates via OTA?
And, is it possible to update the device through the menu "update from memory card" using the file of the latest firmware that you posted?
Thank you.
Fri Apr 21, 2017 7:30 am
Thank you.
We are checking on firmware 20170224-164843, please stay tuned.
We don't do update from memory card, but through your PC.
peluso
Fri Apr 21, 2017 9:24 am
I have firmware 20170224-164843, I do not get update via wi-fi
The forum does not have instructions for correct PC update.
Why not recommend doing it via MicroSD?
Is it recommended a hard reset before updating?
How to do hard reset?
We need correct instructions, thank you.
adamepc
Re: ROM of BV7000 Pro version BV7000_PRO_Blackview_20170411
Fri Apr 21, 2017 11:55 am
That rom described as BV7000_PRO_Blackview_20170411 is actually BV7000_PRO_Blackview_20170224 isn't it? unless someone else has managed to install and get a different build version??
Semi technical UK user
kipkool
Fri Apr 21, 2017 3:38 pm
I installed this version and here is what I get on my device settings:
Security Patch: April 5, 2017
Kernel Version: 3.18.22+
Compilation number: BV7000_PRO_Blackview_20170411
It seems ok
Syncaine
Sun Apr 23, 2017 3:48 pm
In this firmware, there are problems with camera focusing.
Mon Apr 24, 2017 3:35 am
Firmware 20170224-164843, will soon get notice for update.
peluso
Mon Apr 24, 2017 11:29 am
I received firmware 20170320-141341
I tried to update but after restarting in recovery mode, I get an error.
I restarting the phone and everything is ok.
The firmware remains 20170224.
Upgrade does not work properly.
Why did not I receive the firmware 20170411?
