Tomator
Touch screen not functional anymore
Thu Apr 20, 2017 9:30 am
Hi
Today my BV6000 (the one having swollen battery and screen framed by crystal-like fog) fell from a little height (about 40cm) and the screen stopped sensing touch in the lower part of the screen or event "touches itself". I cannot even unlock the phone. How to repair it?
BV6000 P2 BV9500Pro
Re: Touch screen not functional anymore
Thu Apr 20, 2017 10:16 am
Please go to the online shop to check if it is within the warranty time?
Or you can find the local repair shop to mend this?
Tomator
Thu Apr 20, 2017 11:02 am
AE Smartphone Center says they may help only within 3 months. It's not fair to require buy additional warranty while BV gives one year warranty. Usually, when I had problem with equipment under warranty, I was taking it to authorized service for free repair. This is the right way. Only if I hadn't such service in proximity I used the shop I purchased the equipment to make reclamation. Hiding behind the shop that won't help in not honorable way to avoid fulfilling the warranty.
BV6000 P2 BV9500Pro
khubeo
Thu Apr 20, 2017 2:06 pm
You can try connecting a mouse to USB slot and see if this helps unlocking the phone and then maybe resettting factory state.
Tomator
Fri Apr 21, 2017 9:18 am
The sccreen 'touches itself', so I doubt the mouse would be functional. The front panel is to be replaced anyway together with the battery.
BV6000 P2 BV9500Pro
Tomator
Mon Apr 24, 2017 11:04 am
The OTG works and the mouse was able to enter diagnostic mode *#87#. Here is what the phone was feeling while I was using my finger:
Phone's screen sensitive area
Not very good, is it? Resetting the phone to factory defaults didn't help of course. It's apparently hardware problem.
BV6000 P2 BV9500Pro
Tue Apr 25, 2017 9:01 am
Please send the damaged screen picture and your consignee address to service@blackview.hk to get screen replacement, without the picture you will not get the replacement. Please kindly note.
Tomator
Fri Apr 28, 2017 11:59 am
How long it usually takes the service to respond to an e-mail? After first try the answer came after one minute:
The mail system <service@blackview.hk>: host mxdomain.qq.com[183.57.48.35] said: 550 Ip frequency limited.
http://service.mail.qq.com/cgi-bin/help ... no=1000725 (in reply to end of DATA command)
This was automatic failure report so I sent a message again ("Screen replacement required due to touch sensor failure", Apr 27, 08:46 CEST). Until now there is no response. I don't know if they will send me the part or if they even received the e-mail. But maybe it's normal and I'm just too impatient for Chinese standards.
BV6000 P2 BV9500Pro
Tomator
Mon May 08, 2017 11:33 pm
Hi
There is still no response from service@blackview.hk - is this a Chinese custom to ignore and avoid the customers?
BV6000 P2 BV9500Pro
The_Saint
Tue May 09, 2017 12:17 pm
You're making mess in almost every single thread. Why don't you write a PM to admin?
