Upcoming Blackview BV7000
Wed Apr 19, 2017 10:12 am
Upcoming Blackview BV7000, NFC supported, 2GB RAM +16GB internal memory, Android 7.0, processor MT6737T.
With these differences, the low version of BV7000 Pro is coming soon, please stay tuned.
dee-san
Re: Upcoming Blackview BV7000
Thu Apr 20, 2017 1:29 pm
I'm confused:
  • Product page states 2GB RAM + 16GB ROM - which is true now?
  • Why does the "inferior" Edition include NFC, but the superior doesn't?! I was about to get the BV7000 Pro to upgrade my BV6000, but without NFC, it's just pointless
  • Why these overlong 9mm Pin USB Cables? Yes you can buy several on the internet, but the fact is - I want to continue using the cables I already own!
Congrats on the fantastic design though - but please; do another version which is the BV7000 Pro + NFC + normal USB cable pins
Call it BV7000 Pro+ or something 8-)
dee~
Fri Apr 21, 2017 6:32 am
dee-san wrote:
I'm confused:
dee~
Hello, it is 2GB RAM + 16GB ROM. :D
It is something about the design on BV7000 Pro, unable to cover the NFC function.
