  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
Don Harry
Issue after update 20170414
Wed Apr 19, 2017 6:06 am
now it`s very difficult to use the HOME, BACK and MENUE buttons.
The are no more sensitive, its nececary to tip them very hard some times.
CORRECTION of version: Issue after update 20170414
UlmerSpatz
Re: Issue after update 18042016
Wed Apr 19, 2017 6:26 am
The current version Android 7 via OTA is 20170414.
For me this works.
h0w4rd
Wed Apr 19, 2017 7:30 am
The same here :-( - version 2017 04 14
It's lagging very often.
Is it really so difficult to make a working Android system?
Wed Apr 19, 2017 8:20 am
Did you upgrade this by FOTA?
h0w4rd
Wed Apr 19, 2017 8:52 am
yes, of course, I wouldn't know where to download it manually
h0w4rd
Wed Apr 19, 2017 9:16 am
Don Harry wrote:
The problem is not in those buttons, there is no point to press them hard, it's a software problem.
Don Harry
Re: Issue after update 20170414
Wed Apr 19, 2017 9:30 am
Jep = FOTA
97gérard216
Wed Apr 19, 2017 12:29 pm
Android 7.0 Update Successfully BV6000_Blackview_V01_20170414.
mobosenshi
Wed Apr 19, 2017 3:26 pm
No problem here.
custal
Wed Apr 19, 2017 3:31 pm
Same, no problems found, yet.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 11
