mauron
Re: Download link for BV6000 upgrades from Android 6.0 to Android 7.0
Sat Apr 22, 2017 11:26 am
Hi
Another question hoping for an answer.
To upgrade to android 7 which firmware is needed?
Can I upgrade to android 7 from the 20161025 firm?
thanks
SVKR
Sun Apr 23, 2017 7:03 am
Hi admin,
i can't open the link you provided.
SVKR
Sun Apr 23, 2017 7:07 am
blackview_admin wrote:
Hello everyone, please find the link for BV6000 upgrades from Android 6.0 to Android 7.0.
https://mega.nz/#!MfZ1hbaa!zFnwo7aek75x ... lqeyr-EsBI
Hi admin,
it can't be open. Please to check
zimzia
Sun Apr 23, 2017 7:46 am
How to use it ?
Mon Apr 24, 2017 2:13 am
mauron wrote:
HI admin
My bv6000 has never had a fota upgrade. I live in Italy. I updated to 20161025 via local update downloading the package directly to the device and I did not get any updates to android 7.
The update to 7 in this link is only 17mega? it's correct ? Can I proceed by downloading the exe in the bv6000 and updating it locally?
From Android 6.0 to 7.0, you can only update from your PC.
dawan
Mon Apr 24, 2017 6:10 am
hi admin i cant not install the apgrade 7
mauron
Mon Apr 24, 2017 7:14 am
thanks admin
Is there a reason I have never received ota updates on my bv6000 ?
In the future will be possible upgrade to android 7 with a local update?
Mon Apr 24, 2017 8:02 am
Hi admin,
We tried, and opened it, you should wait more seconds.
Mon Apr 24, 2017 8:05 am
mauron wrote:
thanks admin
Currently you should upgrade to android 7 by your PC.
Mon Apr 24, 2017 8:25 am
mauron wrote:
Hi
thanks
Hello, you can upgrade from the latest firmware version on your phone.
ROM of version BV6000_Blackview_V01_20170414
https://mega.nz/#!dLxRSCIS!42alvYGKTr-7 ... F98EPfyWb4
