Don Harry
Issues with Version 20170223
Sat Apr 15, 2017 8:46 am
Buetooth and WIFI are not working well.
All messengers are not working in push mode: Messages are only arriving if the messenger app is opened manually.
Wifi loose conection allways after some minutes.
Bluetooth disconnect and reconnect everey several minutes.
For duty use the phone is useless!
I am surprised that BLACKVIEW cant update this problems since now 8 weeks.
Re: Issues with Version 20170223
Sat Apr 15, 2017 10:11 am
We will fix this problem in the beginning of May.
UlmerSpatz
Sun Apr 16, 2017 9:55 am
So there will be an error-corrected update for Android 7 for all users at the beginning of May? :o
Mon Apr 17, 2017 9:14 am
In the later shipments, all the BV6000 and BV6000S will be upgraded to Android 7.0 in early May.
For the BV6000 and BV6000S on Android 6.0, you can upgrade by your PC, we will release the download link of ROM for all of you to do the upgrade.
UlmerSpatz
Tue Apr 18, 2017 6:46 am
Good news. The current version is a pain.
Tue Apr 18, 2017 8:52 am
Hello, the download link of upgrade on bv6000 from android 6.0 to android 7.0 had been released, you can find on our forum.
Don Harry
Tue Apr 18, 2017 1:07 pm
i just received the 2017.04.14 update
lets try.....
mobosenshi
Tue Apr 18, 2017 1:18 pm
Me too :)
UlmerSpatz
Tue Apr 18, 2017 3:22 pm
Who has already Android 7 Ver 2017-02-23, can install with FOTA the Ver 2017-04-14. Has worked for me.
custal
Tue Apr 18, 2017 10:49 pm
Didn't work. After installation and reboot, I'm still on 20170223, and Wireless Update tells me, there's a new version (20170414) to be had...
