danman
Screen Protector Blackview BV6000
Sat Apr 15, 2017 1:24 am
Hi
I'm experimenting with a number of screen protectors for the BV6000. I'm now on my second tempered glass screen protector and they seem to reduce the sensitivity considerably. The capacitive touch buttons are really slow to respond when using tempered glass so I have to turn on Glove Mode and this seems to help. Unfortunately with glove mode the whole screen is too sensitive.
I've now ordered a nano soft-glass screen protector which is basically a hardened plastic and I'm hoping that will improve the sensitivity of the screen. The plastic film PET film it comes with is fine but I want that extra protection for travelling and having the phone in a bag which will often get crushed.
Anyone found a good touch sensitive screen protector, either tempered glass or nano soft-glass which maintains screen touch sensitivity.
My nano scrreen protector hasn't arrived yet so I can't tell you myself.
PS: Before you say it, I have the pointer speed turned right up ;)
danman
Re: Screen Protector Blackview BV6000
Sun Apr 16, 2017 12:32 am
Does anyone use these forums anymore???
I haven't had a single answer to a single thread I've posted! (which I might add, have taken weeks to appear).
Can anyone even make a recommendation?
Geodarts
Mon Apr 17, 2017 4:19 am
I have had good luck with a brotect "ultra thin" glass protector, but on the other hand I have tried posting four or five things to this forum without one being published . . . So after a while it does not seem worth responding.
Mon Apr 17, 2017 6:01 am
Hello there were some problem before, now we are solving this, everything will be ok soon.
danman
Tue Apr 18, 2017 9:04 am
My posts seem to be going up now. Can you tell me a little more about this screen protector. I have looked at it online.
Is it a good tough screen protector ...and... does it maintain screen touch sensitivity?
At the moment I'm using a tempered glass screen protector (unbranded and cheap). It looks great but the phone is bordering unusable at times if I'm not using Glove Mode. I shouldn't have to.
Tue Apr 18, 2017 10:05 am
If you changed the original screen, you may go to the repair shop to find out the solution.
There are also some repair shops in local place in some country, you can try if they can help.
danman
Wed Apr 19, 2017 5:48 am
I don't think it's the screen. It works fine without the Cheap tempered glass screen protector. There are allot of posts explaining how these remove some of the screen sensitivity.
danman
Sat Apr 22, 2017 11:37 am
Does anyone have trouble with a tempered glass screen protector (specifically pointer speed).
My pointer speed settings don't seem to do anything at all?
danman
Tue Apr 25, 2017 1:24 am
Did anyone put tempered glass on their BV6000? If so, how did it perform?
sams
Thu Apr 27, 2017 1:13 am
I did and it works great, no sensitivity loss. And the pointer speed setting is only for a mouse...
Users browsing this forum: Google Adsense [Bot] and 4 guests
