Solution on BV6000 ads on screen
Thu Apr 13, 2017 3:28 am
Hello everyone, please follow the below steps:
"Go to settings--> apps
Enable system apps (right corner)
Then scroll to ""HTMLViewer""
Open it and set to ""disable""
make sure you remove these kind of apps.
dee-san
Re: Solution on BV6000 ads on screen
Fri Apr 14, 2017 8:53 am
D2nny wrote:
I'm just curious, as why the screenshot is in Dutch?
I didn't expect to find that here?
viewtopic.php?f=144&t=114188#p293572 :lol:
