Solution on BV6000 ads up
Thu Apr 13, 2017 3:26 am
Hello everyone, please follow the below steps:
"Go to settings--> apps
Enable system apps (right corner)
Then scroll to ""HTMLViewer""
Open it and set to ""disable""
make sure you remove these kind of apps.
Whalleyrange234
Re: Solution on BV6000 ads up
Sat Apr 15, 2017 12:46 pm
Tried this and still getting popups.
No longer getting unwanted games installing tho
Phil
Thu May 04, 2017 8:48 am
You could try factory reset or flash a clean rom before disable the HTMLViewer.
