Andrey240@yandex.ru
The proximity sensor
Wed Apr 12, 2017 5:20 am
The problem is the proximity sensor when making a call. It does not always work
Re: The proximity sensor
Wed Apr 12, 2017 7:57 am
Hello, can you please tell more details about your issue? We want to find the exact problem.
If there are some other persons at your side facing the same problem?
Andrey240@yandex.ru
Wed Apr 12, 2017 8:49 am
If I want to find a person from phone book I click on contacts and in the search line to drive the first letters of the name of the desired person, then choose the contact, start calling, and that in such a situation, my proximity sensor is not working. We have lock button, then immediately release the lock on the same button, and then the proximity sensor starts working correctly.
Andrey240@yandex.ru
Wed Apr 12, 2017 8:56 am
Andrey240@yandex.ru
Wed Apr 12, 2017 8:58 am
I can send you the video recording to help you solve the problem.
Andrey240@yandex.ru
Fri Apr 14, 2017 9:34 am
Это видео где видно как работает датчик приближения https://youtu.be/8krY3eWXgOw
Sat Apr 15, 2017 2:35 am
Hi, can you please google to reset this? There is only you having this problem, may not set it decently.
blackviewmember
Sun Aug 13, 2017 1:04 pm
I do have the same problem. Did nothing in the settings. Proximity sensor works even with proximity-test tool. But when making a call the display shuts off (which is correct) but doesn´t go on again when the call is finished.
This was ok when I got the P2 but since 2 months it doesn´t turn the screen on, when I take off the phone from my ear. Display stays dark.
