Netcfm
Bricked phone
Wed Dec 09, 2015 10:13 pm
hello,
I have a problem with a blackview ultra that i bought in comebuy in january. It works fine but yesterday does not switch on. Only appears blackview screen and later inverted blackview screen. ¿?
I have tried to connect it throught usb cable but usb debuggin was off.
I have tried to make a recovey but i only can access to a boot menu pussing vol+ and power. There are three options: recovery, fastboot, normal. I can move with vol+ but i can not select with vol-. I push it and nothing happends.
I have tried with factory mode pushing vol- and power. I can move with vol- but i can find only tests options.
Can you help me? please.
Thanks.
Re: Bricked phone
Mon Jan 11, 2016 10:41 am
hi , is the touch screen works ?
You can try to select with touch screen ?
Best regards,
Admin
katalinfgurzo
Re: Bricked phone
Sun Apr 23, 2017 9:38 am
every blackview 'phone' is go brick very soon............. after purchase
