tingcher
Compass not working - Bosch BMC056
Wed Dec 09, 2015 9:54 am
I have just received this phone and I am really impress with it. Rugged built and quite fast. Everything are working as it should be except when I run the google map, change to point of view and found out the this phone doesn't rotate the map when my point of view has change. It's compass is not working. To confirm, I downloaded three compass apps and none of them is working.
I make search on the web on this problem and did found some other user having the same problem. You can see some asking about compass in the following review comments. http://www.gizchina.com/2015/11/06/blac ... 00-review/
I run Antutu and it did detect BOSCH BMC056 digital compass is present. Seem like the rom or the driver glitch.
Can let me know how to fix this or you guys will fix it in the next coming rom update? Let me know. Thanks.
nyfd_it
Re: Compass not working - Bosch BMC056
Fri Dec 11, 2015 1:01 pm
I am one of the users was asking about compass under the review.
It seems that the BV5000 do not support such a function: viewtopic.php?f=96&t=1176#p1937
