jonathanhowes
Phone wont boot
Fri Apr 07, 2017 12:59 am
Hi
I bought a BV6000 on Amazon.ca in December.
The phone has developed an issue and won't boot.
The boot screen shows the Blackview logo but then never boots, then the screen goes black then shows the logo and so on.
Is the phone covered under warranty?
Can you help me?
Thanks
Jonathan
:cry:
Re: Phone wont boot
Fri Apr 07, 2017 2:42 am
Hi friend, before this happened, did you do something or setting on your phone?
Can you please send some pictures for our reference?
jonathanhowes
Re: Phone wont boot
Wed Apr 19, 2017 5:59 pm
HI
I didn't do anything, but some apps updated from the google store.
It just rebooted it self and hasn't come back to life since :-(
jonathanhowes
Re: Phone wont boot
Thu Apr 27, 2017 10:48 pm
Hi - the phone now wont even turn on.
Can Blackview PLEASE PLEASE help me?
I need a replacement phone as this just doesnt work.
jonathanhowes
Re: Phone wont boot
Thu Apr 27, 2017 10:55 pm
My phone doesn't work.
I believe it is covered by warranty, can you please fix this for me?
I own three Blackview phones and was considering buying another.
If your support cannot help me though i will go with another vendor.
PLEASE HELP ME
Rgds
Jonathan
jonathanhowes
Re: Phone wont boot
Thu Apr 27, 2017 11:13 pm
See photos
Phone only has these two views - ON
Phone only has these two views - OFF
jonathanhowes
Re: Phone wont boot
Thu Apr 27, 2017 11:14 pm
Re: Phone wont boot
Fri Apr 28, 2017 6:40 am
Have you checked if the phone is out of power or can not be charged?
How long have you used your phone, if this is the damage issue, you can check with the re-seller if the phone is still covering warranty time.
jonathanhowes
Re: Phone wont boot
Mon May 01, 2017 5:57 pm
The phone reboots to that screen then turns off, that is all it does.
If i leave it plugged in it just loops like that for ever.
If i unplug it eventually runs out of battery and turns off.
I bought this off Amazon.ca, but the vendor is no longer active and cannot be contacted - so you are my only hope.
Can you help me or not?
Please advise soonest, as I need this fixed and I also need another new phone for my wife.
If you guys don't support your handsets, then i will go and buy a different brand
Re: Phone wont boot
Tue May 02, 2017 6:52 am
Hi, when this started and what have you done with your phone before this happened?
