bituerbo
BV7000 Pro not working in Canada
Wed Mar 29, 2017 11:08 pm
I was happily using my BV6000 and had a BV7000 Pro on pre-order, it arrived yesterday.
I have no connectivity on my Koodo (Telus) SIM and only Edge (2G) connectivity on my Rogers SIM.
Both SIMs identify the provider correctly but Koodo SIM cannot locate a network.
I noticed BV6000 supports 1900mhz and BV7000 Pro does not - did this change mean I can no longer use Blackview with either provider in Canada?
Phone Frequencies: (viewtopic.php?f=175&t=112098)
GSM spec 850/900/1800/1900
3G spec 900/2100
LTE spec B1/3/7/8/20
Provider frequencies below:
Telus (including Koodo)
2G
CDMA 850/1900
EVDO 850/1900
3G (and fake 4G)
HSDPA 850/1900
HSPA+ 850/1900
UMTS 850/1900
WCDMA 850/1900
1x EV-DO CDMA2000
4G (called 4G+)
LTE 1700/2100
Rogers (including Fido, Petro-Canada Mobility)
2G
GSM 850/1900
GPRS 850/1900
EDGE 850/1900
3G (and fake 4G)
HSDPA 850/1900
HSPA+ 850/1900
UMTS 850/1900
WCDMA 850/1900
4G
LTE 1700
Re: BV7000 Pro not working in Canada
Thu Mar 30, 2017 2:42 am
As for BV7000 Pro, it can not working currently in Canada.
bituerbo
Thu Mar 30, 2017 2:40 pm
Did I misunderstand the frequencies? I checked before ordering and as I mentioned, my BV6000 is working fine.
Is it possible an update will fix network compatibility? Or should I contact seller (Desoon) for refund?
bituerbo
Wed Apr 05, 2017 4:18 pm
Had a friend test in US - BV7000 Pro does not work in all of North America.
Big market to exclude!
AceMcCool
Thu Apr 20, 2017 4:14 am
ADMIN can you say why it won't work in canada? I spent months researching it to make sure the bands match. I ordered it and find it won't work for me too. I am in Canada
Fri Apr 21, 2017 7:04 am
Hello everyone, we have reported your issues, and are looking for the solution, please stay tuned.
Abdiel94
Fri Apr 21, 2017 9:47 pm
Hi. I have the same problem in MEXICO. My 7000pro only connect to 2G Edge. Have signal to call but no to internet
Derk
Fri Apr 21, 2017 9:56 pm
Obviously the advertised frequencies are not fully supported.
So send back your phone or file a claim for wrong advertising...
AceMcCool
Sat Apr 22, 2017 4:33 pm
Thank you blackview_admin for looking into the issue, I look forward to a solution. I really like my BV7000 Pro and to have it work in Canada would be awesome.
adampeek
Sat Apr 22, 2017 5:33 pm
I too can confirm the BV7000 Pro does not work in the United States either. Bitter disappointment.
