adamepc
FIX the official ROM please to remove developer flags
Wed Mar 29, 2017 12:49 pm
Your official stock rom has test keys in the build still switched on which is making certain apps like banking apps and Android Pay not work as they think the ROM is rooted or customised. One of the main reasons I went for this phone was due to the fingerprint so I could use these services.
NO I HAVE NOT ROOTED THE DEVICE IT IS DUE TO YOUR STOCK ROM
Semi technical UK user
Re: FIX the official ROM please to remove developer flags
Thu Mar 30, 2017 2:59 am
Can you please tell more details or offer some video or picture for reference? also please tell your location.
adamepc
Thu Mar 30, 2017 7:11 am
You won't need pictures or a video simply install a root checker such as 'Simply Unroot' and it will tell you about the developer flags.
Alternatively try install Android Pay and it will tell you it thinks the ROM is rooted or a custom ROM
I'm in the UK but that won't make much difference. Im on ROM version BV7000_PRO_Blackview_20170224, which came shipped with the device and cannot find anywhere to download an uptown date version if there is one
Davros84
Sun Apr 02, 2017 3:36 am
I have the same issue. Some apps will not work because i get this error saying "your device appears to be rooted. This application cannot run on a rooted device"
Derk
Mon Apr 03, 2017 3:53 pm
That is no new issue, the Blackview DEVs are doing it all the time.
The issue and correct procedure I explained in this post http://bbs.blackview.hk/viewtopic.php?f=142&t=62784&p=70569#p70569 over 6 months ago, but at Blackview nobody cares about correct Android development procedures!
Davros84
Tue Apr 04, 2017 10:51 am
I have the same issue when trying to run apps. I get a message saying that the app can not run because the phone is rooted. I have had the bv7000 for 4 days now.
Thu Apr 06, 2017 6:56 am
Hi friend, thanks for getting in touch. We are looking for the solution about this issue. We will release the solution timely on our official forum if any update. Please keep tuned.
Fri Apr 07, 2017 2:19 am
Hello everyone, as for BV7000 Pro, some apps like google pay or android pay can not work in this phone.
Sorry for this inconvenient.
adamepc
Fri Apr 07, 2017 8:47 am
Can we take the previous statement to mean you will not be fixing the ROM then?
What could have been a great phone is ruined by hundreds of niggles like not being able to use ANY but the cable that came with the phone for charging or headphones and a really really bad ROM.
If you're not going to fix the ROM can you upload the tools needed to build our own or shall we just give up on Black view?
Davros84
Sun Apr 09, 2017 8:23 am
Anyone else have the nvram warning error on wifi?
