luc.alquier
BV6000_Blackview_V01_20161011 trojan and adware
Wed Mar 29, 2017 8:47 am
My phone firmware version :
-BV6000_Blackview_V01_20161011
- kernel version 3.18.22\root@agoid1504 #2\Wed Oct 12 09:09:51
Please can you give us a firmware updated in order to remove these presinstalled malware ?
- /system/priv-app/HTMLViewer/HTMLViewer.apk
- /system/app/AdupsFota/AdupsFota.apk
Re: BV6000_Blackview_V01_20161011 trojan and adware
Thu Mar 30, 2017 3:28 am
Hi friend, thanks for getting in touch. We are looking for the solution about this issue. We will release the solution timely on our official forum if any update. Please keep tuned.
DunnerStunner
Thu Mar 30, 2017 8:39 am
I've had this issue too!
Phone started running really slowly and started downloading random apps! :o
MDC60
Tue Apr 04, 2017 3:38 am
HI,
I ve changed ROM to avoid AdupsFota but no result. The backdoor is in system. So, waiting for admin solution. Thks.
Best regards.
necromia
Tue Apr 04, 2017 9:01 pm
This is common problem of non EU/US phones (read Chinese phones)
Best non bloated phone is the Google Phones period (and the safest among the Androids - if you don't buy a secure phone, but that a totally different thing and cost a lot)
You need to root the phone to remove all the unknowns - this is not easy on system files unfortunately.
Had some friends that ordered Chinese Phones - they are low price, quite good hardware (microphones/speakers and other parts (connectors etc) can be substandard to save money) but software Security wise they are a mess (push pop ups, apps that appear from thin air and all kinds of strange things)
Kladblok2001
Fri Apr 07, 2017 8:35 pm
Go to settings--> apps
Enable system apps (right corner)
Then scroll to "HTMLViewer"
Open it and set to "disable"
This app is infected. It was already installed when I bought the phone. I don't have the pop-ups anymore, and no self installing apps with names like "Phone", or "Call" or "XXX"
make sure you remove these kind of apps.
HTMLViewer can't be removed without rooting.
W.S.A
Sun Apr 09, 2017 1:13 pm
Hello, check out thic artcile about adupt soft:
https://android.gadgethacks.com/how-to/ ... e-0175034/
I am been disabled adupt auto updater for my phone.
Thu Apr 13, 2017 3:05 am
Dear W.S.A. and kladblock2001, both of you are really doing a great help, thanks very much.
mauron
Mon Apr 24, 2017 3:17 pm
Hi
i have 20161025 and /system/app/AdupsFota/AdupsFota.apk is infected of pup.adware.yemobi.a
I would like to eliminate the threat
But my bv6000 does not receive fota updates and can not make local updates
viewtopic.php?f=144&t=118008&start=10#p301339
and with the W.S.A. procedure I could never update the phone again
or not?
I can not update through pc because I do not have windows 10
thanks
yoyotogo
Tue May 23, 2017 8:15 pm
I DO CONFIRM THAT the software "DEBLOATER" works to FREEZE the Adups FOTA trojan
http://rootjunkysdl.com/files/?dir=Gates/DeBloater
thanks a lot
