sidsood
Camera shutter makes sound each time.
Tue Mar 28, 2017 6:06 pm
I have the Blackview BV6000 and its camera makes a loud shutter sound everytime I am clicking a picture or recording a video. It is gets too irritating at times. Is there a way to get this done without using any app?
Thanks in advance.
Re: Camera shutter makes sound each time.
Wed Mar 29, 2017 2:53 am
Hi friend, thanks for getting in touch. Can you please tell your location and tell us your building no. of your phone?
sidsood
Wed Mar 29, 2017 7:23 am
Build number : BV6000_Blackview_V01_20161011
Fri Mar 31, 2017 2:25 am
Hi friend, thanks for getting in touch. We are looking for the solution about this issue. We will release the solution timely on our official forum if any update. Please keep tuned.
gvm87
Fri Mar 31, 2017 6:37 am
Try putting the phone on silent and then using the camera
sidsood
Fri Mar 31, 2017 12:37 pm
Keeping my phone on silent doesn't work.
Smash
Sun Apr 02, 2017 8:21 am
Got the same problem, my BV6000 is only 2 weeks old. So annoying.
Build number: BV6000_Blackview_V01_20161011
I´m waiting for the solution.
Tomator
Tue Apr 04, 2017 8:20 am
It's a general agreement, including OS providera as well as device manufacturers, that due to privacy protection the camera should always sound when taking pictures. There were even legislation projects to enforce this behavior. I don know though if they were introduced.
BV6000 P2 BV9500Pro
Thu Apr 06, 2017 5:52 am
khubeo
Tue Apr 25, 2017 8:13 pm
Disabling shutter click is actually quite easy, but you need to root your phone first in order to have access to system files folder. Then you go to system/media/audio/ui, find the file "camera_click.ogg" and change its name to, for instance, "camera_clic.ogg". After that you take silent pictures. Changing the name back restores the shutter sound.
