maxcalce
File BPLGUI
Sat Mar 25, 2017 9:15 am
good morning.
I switched from Android 7 to 6 for battery problem.
I lost IMEI, and I need the BPLGUI files to try to recover.
thank you
Re: File BPLGUI
Mon Mar 27, 2017 1:53 am
Hi friend, after switching, usually it will not lost the IMEI.
Did you format your phone? If you didn't do this, you can use the coding tool to re-write the IMEI.
Users browsing this forum: Baidu [Spider] and 0 guests
