malal
NO SIM CARD message [Brand New BV6000]
Thu Mar 23, 2017 7:31 pm
Hi everyone,
I just received my BV6000 and was super happy about it, till it tried to make it work...
I keep having the no sim card message, although i tried to :
Restart the phone
update the firmware
restart the phone and use the other slot
use the factory reset
restart the phone again.
i am on French network FREE.
I put back my sim in my former phone and it works like a charm so i really think the problem comes from the BV6000.
Would anyone have any intel before i send it back and go buy an iPhone with a lifeproof case :( ?
Thanks in advance
BR
Re: NO SIM CARD message [Brand New BV6000]
Fri Mar 24, 2017 2:09 am
Hi friend, please check if the sim card is connected well with the slot?
khubeo
Fri Mar 24, 2017 6:51 am
See if your IMEIs are correct.
khubeo
Sat Mar 25, 2017 6:07 am
See if your IMEIs are OK.
khubeo
Sat Mar 25, 2017 5:13 pm
See if your IMEIs are ok.
brsc0425
Tue Mar 28, 2017 9:47 pm
I have the same problem, plus external speaker not working too.
How do I fix these problems?
Darren Jenkin
Wed Apr 19, 2017 5:49 am
had same problem, then downloaded firmware file to fix but BRICKED phone instead
