grAwp
Loose battery on BV6000
Thu Mar 23, 2017 11:11 am
Dear Blackview,
a few days ago i have a problem with my BV 6000 with some noise inside of the phone. The BV 6000 falling down on the ground much times before this problem :? . I think that sound is causing by the battery which are loose and knocking inside of the phone. What can i do repair it :?:
Thank you very much
Alain 76
Re: Loose battery on BV6000
Fri Mar 24, 2017 1:09 pm
Hello, personally, I opened the blackview BV6000 and add between the back cover and the battery a thickness of cardboard resistant to heat and the problem has been fixed.
mobosenshi
Fri Mar 24, 2017 5:58 pm
I had the same issue. The battery magically glued itself back :D
Spinebreaker
Sat Mar 25, 2017 8:17 pm
What kind of question is that? :shock:
Open the phone and fix it :roll:
