luchoguerra
camara bv6000, funciona mal
Tue Mar 21, 2017 9:12 pm
hola, cuando pongo la camara e intento sacar una foto se cierra la aplicacion. y no se puede sacar el sonido del obturador. aguien podria ayudarme?
Re: camara bv6000, funciona mal
Wed Mar 22, 2017 1:34 am
Hi friend, can you please speak in English? Also please tell your location and send the video or picture for reference.
custal
Wed Mar 22, 2017 8:05 am
Roughly translated:
Hello, when I use the phone and try to take a photo, the application is closed and the shutter sound cannot be removed. Can you help me?
Thu Mar 23, 2017 6:51 am
custal wrote:
Roughly translated:
Hi friend, you can do the camera setting and close the sound if you don't like it, you can google to find how to do this setting.
ravee1010
Fri Mar 24, 2017 11:06 pm
Blackview admin
How to.stop shutter sound??
jdmarques
Sun Mar 26, 2017 8:25 am
Good morning
I hava a blackview bv6000 and simply the rear camara stop working and the front camara its upside down!
What can i do to repair it?
Best regards
Jose marques
luchoguerra
Sun Mar 26, 2017 8:10 pm
Soy de Argentina.. el teléfono no tiene ninguna opción para quitar el sonido..
La aplicación se cierra cuando saco la foto..
I am from Argentina .. the phone has no option to remove the sound ..
The application closes when I take the photo ..
