Nikolay
hard reset
Tue Mar 21, 2017 5:29 am
Conducted a hard reset on the phone, wifi works fine, mobile data is not enabled, the phone is working well but for some reason after screen lock the phone closes all apps, and even antivirus. After unlocking your phone you have to run every time anti-virus and other applications. Thanks for the help in solving the problem.
