Which would you prefer, BV7000 Pro or BV7000?
Tue Mar 21, 2017 1:53 am
With different CPU, storage and camera pixel, etc. Which would you prefer, BV7000 Pro or BV7000?
We will be much appreciated if you could leave your comments here. Please just let us know your idea, thank you.
kkleung
Re: Which would you prefer, BV7000 Pro or BV7000?
Tue Mar 21, 2017 3:14 am
I prefer BV7000 pro. Before I buy it, I need to know how to attach security strap (安全卦繩) since I'll use it in watersports. I don't use NFC.
GillesB
Tue Mar 21, 2017 8:12 pm
Clearly the BV7000 Pro! Camera, CPU power, RAM AND ROM are important for my use.
CoastalBudgetBuilds
Tue Mar 21, 2017 10:05 pm
I have the BV7000 pro... just got it today and it wont charge..... im super upset
Wed Mar 22, 2017 1:24 am
Hi friend, can you please tell your location and send the video or picture for reference?
Netsplitz
Wed Mar 22, 2017 4:38 am
Any chance of a BV7000 pro with NFC? Also the current 3G/4G band support of the BV7000 pro is worse than BV6000.
chrisb
Wed Mar 22, 2017 1:37 pm
Bv7000 because of NFC, but rom is lacking, does it have a micro SD slot?
smoke
Sat Mar 25, 2017 12:35 pm
In the pro the second SIM is using the slot of rhe SD. :cry:
it was NOT correctly documented.
The SD should have had a stand alone slot....
CoastalBudgetBuilds
Sun Mar 26, 2017 6:20 pm
I would like the BV7000 Pro if it would hold a charge... When I plug it in nothing happens......
