coolchoi
Endless rebooting
Mon Mar 20, 2017 3:26 pm
I like P2 very much.
It works well in Vietnam but I found some material problem when I brought my phone with KT sime card added in Korea.
Continuous rebooting whenever I open apps or install new apps.
Please help me.
Re: Endless rebooting
Tue Mar 21, 2017 2:20 am
Hi friend, can you please send the video or some pictures for reference?
coolchoi
Wed Mar 22, 2017 10:11 am
Thanks for reply.
In fact, I have tried to reset to factory setting even without sim cards here in Korea. But I don't think I can go back to original setting because I saw several errors right after I reset and added my google account then turn off and on continuously.
"Google Play Store stopped", "Google Play service stopped", "System UI stopped" then turned off and on.
I just like to go back to original setting.
Thu Mar 23, 2017 2:08 am
coolchoi wrote:
Thanks for reply.
Hi friend, please follow the steps:
Turn off the phone--press the "power key+volume" at the same time to enter into the reset.
Please kindly note that after the factory reset, your phone may get some problem if you are not skillful in this.
coolchoi
Sat Mar 25, 2017 8:51 am
If some problem happens, any way to fix?
Please help me.
