kowsiu
I can't update 20160919
Sun Mar 19, 2017 6:29 pm
I have got BV6000 with software 20160919. I installed this ROM (I found it on this forum) with Local update, because I had problems with root cheking. Now I can`t update my BV6000. When I click "Check for updates" I see "Your system is currently up to date". I try install 20161025 by Local update, but it don`t work, the smartphone don`t restart (I see first "Pasting..." and later all the time "Reboot...") What can I do? I try send messege by Feedback, but no answer... Please help me :)
Re: I can't update 20160919
Tue Mar 21, 2017 2:51 am
Hi friend, can you please tell your location and send the video or picture for reference?
kowsiu
Tue Mar 21, 2017 9:05 am
kowsiu
Tue Apr 18, 2017 3:53 pm
Help pls
Rvascon18
Tue Apr 18, 2017 7:42 pm
I can not update it either, I tried to download it and update it but it does not change at all. I am from paraguay
Parcheval
Wed Apr 19, 2017 5:40 pm
Download the desired ROM flash file from here:
viewtopic.php?f=144&t=101183#p284253
then follow the procedure mentioned here:
viewtopic.php?f=144&t=54240
