tomithyom
BV6000 Android 7.0 keyboard (No Microphone)?
Sat Mar 18, 2017 7:16 am
I have just bought the Blackview BV6000, it looks tough enough for what I want it for. Feels great.. But.......
This phone came with Android 7.0 installed. It uses a Android AOSP keyboard version 7.0.
For some reason I cannot get the small microphone to the left of the space-bar to appear. It's very annoying.. I'm on the verge of sending the phone back as this is an essential feature.
I have turned on Google Voice typing and set all the settings correctly in 'Language and Input' in the settings menu.
I have also factory reset the phone. Still no luck.
Does anyone know how to get the voice typing symbol to appear?
Any help would be greatly appreciated.
Re: BV6000 Android 7.0 keyboard (No Microphone)?
Tue Mar 21, 2017 3:37 am
Hi friend, can you please tell your location and send the video or picture for reference?
Tomator
Tue Mar 21, 2017 9:18 am
It's a bit tricky. I was exploring input options and Google's voice typing could be enabled. The phone and system are fine, that's matter of configuration. Google keyboard should be installed I think. Then the microphone icon on right top appears and I can also change keyboard and language or switch to voice by long-press the space bar.
BV6000 P2 BV9500Pro
tomithyom
Tue Mar 21, 2017 9:36 am
Hi there. Thanks for the reply.
I was hoping to use the existing AOSP stock android keyboard. I really wanted to avoid installing anything else so I'm baffled why the microphone won't appear.
Yes, google voice typing is enabled.
Can't figure it out.
I think it must be an issue with the Android 7 upgrade on the Blackview BV6000. Does anyone else have this phone??
If so can you see the microphone to the left of the space bar on the stock AOSP android keyboard? If so, is that on Android 7 or 6.
Thanks
tomithyom
Tue Mar 21, 2017 9:43 am
Hi Blackview_Admin. I've already emailed you directly about this.
Here is a picture of what I currently see on my keyboard. I see a comma where a microphone should be.
keyboard2 (1).jpg (163.25 KiB) Viewed 4223 times
Thanks
tomithyom
Wed Mar 22, 2017 7:08 pm
I made another post on this thread two days ago.. Where did it go?
WarrenRABS
BV6000 Android 7 0 keyboard No Microphone
Thu Mar 23, 2017 7:34 am
Hi
I have the same problem - I need to show suggestions on the keyboard on Android. I was wondering if you did find a solution?
tomithyom
Thu Mar 23, 2017 10:44 am
bump
