Re: Google Dialer and root
Tue Mar 21, 2017 2:56 am
Hi friend, if it is not compatible with this phone, you may not install it.
custal
Wed Mar 22, 2017 2:56 pm
The possibility to easily activate root access would be great.
mobosenshi
Wed Mar 22, 2017 9:36 pm
What's your firmware? I successfully installed Google Dialer on my BV6000.
Aimless
Wed Mar 22, 2017 11:44 pm
For this to work, you have to change permissions in etc/permissions and framework or it won't run.
custal
Thu Mar 23, 2017 7:27 am
Try version 2.05.xx ... works fine.
D2nny
Thu Mar 23, 2017 8:25 pm
I had Google Dialer running fine on Android v6, but no longer on v7
Thanks for the tip, I just downloaded the APK for 2.5.12_rc9-release, but unfortunately it failed again;
App not installed.
This app isn't compatible with your phone.
custal
Fri Mar 24, 2017 7:32 am
I'm running 2.05.07_rc4 on Android 7 without problems.
