gamernayan
How to get Android 7.0 wireless update after hard reset?
Tue Mar 14, 2017 10:40 am
I had some problems with my device and after performing hard reset it is showing July 5,2016 patch level, Build no. 20161011.
I tried wireless update but it is showing my system is currently upto date.
How can I get Andriod 7.0 after this?
Need help plz.
Re: How to get Android 7.0 wireless update after hard reset?
Wed Mar 15, 2017 2:24 am
Hi friend, can you please tell your location for reference? And also please send some picture.
gamernayan
Wed Mar 15, 2017 9:48 am
My location is Abu Dhabi, UAE.
Plz see the attached pictures during the update.
Parcheval
Wed Mar 15, 2017 12:34 pm
Get the local 20161025 ROM from here viewtopic.php?f=144&t=101183#p284253 and perform a local update following this viewtopic.php?f=144&t=41724
Afterwards you should get Android 7 updates over the air (OTA)
gamernayan
Sun Mar 19, 2017 3:25 am
gamernayan
Tue Mar 21, 2017 6:48 am
I've replied to this post twice as you asked my location but why it is not posted? I'm i being ignored?
Fix this issue asap.
