HBrito
Battery charging time
Mon Mar 13, 2017 5:39 pm
Folks, after upgrading to Android 7.0, my BV6000 takes more than 10 hours to load 100%. What can I do to solve this problem? Thanks.
Re: Battery charging time
Tue Mar 14, 2017 6:31 am
Can you please tell your location for reference? We will reported your issue to our technical department.
bregos
Tue Mar 28, 2017 7:27 pm
I just purchase a new one yesterday with android 7 and I have the same issue.
I'm charging the phone with the factory charger.
And with a voltage tester I see that the charging voltage it isn't stable.
From 5v go up to 7v, 9v then 12v and after that step to 5v. This is the charging cycle.
Regards
