h0w4rd
7.0 - Wifi keeps connecting and disconnecting
Sun Mar 12, 2017 11:53 am
After upgrade to 7.0 wifi is disconnecting and connecting over and over again every about minute.
No other device does that and it was OK with 6.0.
Factory reset didn't solve it.
Please see the attached wifi log.
What can I do with it? Or is it a bug?
wifi.zip
wifi log
(713 Bytes) Downloaded 459 times
Re: 7.0 - Wifi keeps connecting and disconnecting
Mon Mar 13, 2017 3:42 am
Can you please tell your location?
h0w4rd
Mon Mar 13, 2017 7:44 pm
Czech rep., why are you asking?
Tue Mar 14, 2017 6:29 am
We will need the location for reference.
We already reported your issue to our technical department, any update, we will share it in our official forum, please keep tuned. Thanks.
Netsplitz
Sun Mar 19, 2017 1:07 am
i am having wifi problem too after upgrading to Android 7.
Mike6666
Sun Mar 19, 2017 7:34 pm
My BV6000 disconnects after the screen goes into sleepmode. Even if I do not want to turn the wifi off in battery saving mode it disconnects.
Mon Mar 20, 2017 8:17 am
Hi friend, we already reported this issue to our technical department, if any update we will share it timely on forum .
Gazlee
Sat Apr 01, 2017 12:31 pm
Since updating to android 7 I'm having all sorts of issues my bv6000... the WiFi disconnects when the screen goes to sleep, it doesn't save new contacts are just a couple of the problem's I'm experiencing. .. I'm in England.
h0w4rd
Tue Apr 18, 2017 9:44 pm
Update 20170414 installed.
I'm still experiencing the same problems with wifi.
I would be grateful for more detailed changelog. Just bugfixes is not enough. Thank you.
custal
Tue Apr 18, 2017 10:41 pm
Does your WiFi router check your devices' MAC addresses by any chance?
After updating to Android 7, I couldn't connect to my WLAN since my BV6000's MAC changed, for whatever reason.
