Spinebreaker
Video Recording weird clicking sounds
Sat Mar 11, 2017 9:04 am
Hi, no matter if I use Android 6 or 7 I always have weird clicking sounds when I record video (stock app and other apps as well).
Ist there any tweak or fix for it? Can I do anything in the Engineer mode or so?
Re: Video Recording weird clicking sounds
Mon Mar 13, 2017 3:54 am
Can you please tell your location?
Phil
Mon Mar 13, 2017 11:59 am
I noticed the same issue in Germany.
I guess its an hardware bug: the clicking sound is made from the camera autofocus and the sound recording in video is getting this very loud.
As a workaround I use an other camera app (open camera) where I can set the sound source for video to "optimised for voice". That makes the clicking sound much quieter (but its still there).
Ravelo78
Mon Mar 13, 2017 1:14 pm
Have you active microphone in Camera/Video/Setting ?
Spinebreaker
Mon Mar 13, 2017 9:05 pm
Iam from Germany as well.
The noise is triggered when the phone is moved. If you hold the phone still while recording the is no clicking noise. But every slight move triggers it.
I also figured out that it has something to do with the exposure.
I made some test shots with mys phone for you/the developers. Please forward it so this anoying bug can get fixed soon.
https://goo.gl/photos/uKwMSBRU1N4CW9FV6
I also found out that when I shot a video with the inbuild camera of Line (Chatclient like Whatsapp) the sound is cristal clear.
Tue Mar 14, 2017 5:58 am
We have reported this issue to our quality department, any update, we will share the solution in our forum, please kindly keep tuned.
The important: Can you please send some video about this issue?
bvbw
Tue Mar 14, 2017 7:25 am
Same problem for me ...
lot's of weird clicking sounds when video Recording.
BV6000 Android 7.0
Location France
BV6000
Tue Mar 14, 2017 2:09 pm
same problem at Spain
Spinebreaker
Tue Mar 14, 2017 6:39 pm
Wed Mar 15, 2017 8:25 am
Hi friend, we reported your issue to our technical department. We will share the solution timely if any news, please keep tuned.
